跳转到主内容
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: 步骤 1 中的图像 1,2 Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: 步骤 1 中的图像 2,2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: 步骤 2 中的图像 1,2 Canon EOS 60D: Replacing Eye piece and Battery door: 步骤 2 中的图像 2,2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
结论
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
4等其他人完成本指南。
Eric D
于11/13/12注册
1,284 声望
创作了5篇指南
一条评论
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 30
总计 5,940
