跳转到主内容
Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement
你所需要的
  1. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: 步骤 1 中的图像 1,3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: 步骤 1 中的图像 2,3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement, Top Digital Display Clear Plastic Cover: 步骤 1 中的图像 3,3
    • Hold the camera in a top view position allowing for a clear display of the broken top cover.
    • Observe and identify all the pieces of the shattered cover.
  2. Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: 步骤 2 中的图像 1,3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: 步骤 2 中的图像 2,3 Canon EOS 60D Top Digital Display Clear Plastic Cover Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Slowly slide the tip of the tweezers under a piece of the broken cover and lift up to remove the broken piece.
    • Use the tweezers to remove another piece of the broken cover.
    • Repeat until all the pieces of the shattered cover are removed.
    • If you begin by removing a piece that is located at an edge of the broken cover, it would facilitate the removal of the rest of the pieces.
    • Use the tweezers carefully while removing the plastic pieces in order to avoid damaging the LCD screen beneath.
结论
7等其他人完成本指南。
Nazmi Bargouthi
于08/26/15注册
591 声望
创作了2篇指南
团队
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G6
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 3,357
