简介
If you drop the camera and break the LCD screen, or if the screen just stops functioning, this guide will help you replace it.
Be sure to use a magnetic mat or small container for your screws, as they are very small and easy to misplace.
你所需要的
Take the LCD out of its place to expose the Phillips #PH00 screws.
Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
4等其他人完成本指南。
