跳转到主内容
Canon EOS 60D Rear LCD Screen Removal
你所需要的
  1. Canon EOS 60D Rear LCD Screen Removal, Rear LCD Screen Dissasembly: 步骤 1 中的图像 1,1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Removal: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Removal: 步骤 3 中的图像 1,2 Canon EOS 60D Rear LCD Screen Removal: 步骤 3 中的图像 2,2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Removal: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
结论
2等其他人完成本指南。
Tyler Vaal
于08/30/15注册
731 声望
创作了3篇指南
团队
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G6
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,558
