跳转到主内容
Canon EOS 60D Rear Cover Removal
你所需要的
  1. Canon EOS 60D Rear Cover Removal, Rear LCD Screen Dissasembly: 步骤 1 中的图像 1,1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear Cover Removal: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear Cover Removal: 步骤 3 中的图像 1,2 Canon EOS 60D Rear Cover Removal: 步骤 3 中的图像 2,2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear Cover Removal: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: 步骤 5 中的图像 1,2 Canon EOS 60D Rear Cover Removal, Removing Rear Cover: 步骤 5 中的图像 2,2
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
  6. Canon EOS 60D Rear Cover Removal: 步骤 6 中的图像 1,2 Canon EOS 60D Rear Cover Removal: 步骤 6 中的图像 2,2
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
  7. Canon EOS 60D Rear Cover Removal: 步骤 7 中的图像 1,1
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
  8. Canon EOS 60D Rear Cover Removal: 步骤 8 中的图像 1,2 Canon EOS 60D Rear Cover Removal: 步骤 8 中的图像 2,2
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
  9. Canon EOS 60D Rear Cover Removal: 步骤 9 中的图像 1,2 Canon EOS 60D Rear Cover Removal: 步骤 9 中的图像 2,2
    • Using the plastic opening tool, carefully pry off the the side cover.
  10. Canon EOS 60D Rear Cover Removal: 步骤 10 中的图像 1,1
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
  11. Canon EOS 60D Rear Cover Removal: 步骤 11 中的图像 1,1
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
  12. Canon EOS 60D Rear Cover Removal: 步骤 12 中的图像 1,1
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
结论
另外一个人完成了本指南。
Tyler Vaal
于08/30/15注册
731 声望
创作了3篇指南
团队
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G6
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 30
总计 2,724
