跳转到主内容
Canon EOS 5D Mark II LCD Window Replacement
你所需要的
  1. Canon EOS 5D Mark II LCD Window Replacement, LCD Window: 步骤 1 中的图像 1,1
    • Here is the part we need to replace with a new LCD lens.
  2. Canon EOS 5D Mark II LCD Window Replacement: 步骤 2 中的图像 1,1
    • Using a hairdryer or heat gun, heat up the lens for removal. This should not take longer than 30 seconds.
    • Now using a suction cup, I used a suction from a sponge,apply the suction cup to the plastic lens. Now just pull the lens away from the camera to remove the old lens. This may require a small amount of force.
    • If it does not want to budge, try reheating.
  3. Canon EOS 5D Mark II LCD Window Replacement: 步骤 3 中的图像 1,1
    • At this step you may need to reheat the bottom of the lens if it does not come fully off.
    • You may need to cover the cracked area of the screen with a screen protector, or just regular packing tape. After removal, clean off remaining adhesive.
  4. Canon EOS 5D Mark II LCD Window Replacement: 步骤 4 中的图像 1,2 Canon EOS 5D Mark II LCD Window Replacement: 步骤 4 中的图像 2,2
    • After removal, make sure to remove all pieces of the old lens. Checking for fragments of plastic, and dust on the LCD.
  5. Canon EOS 5D Mark II LCD Window Replacement: 步骤 5 中的图像 1,1
    • Now grab your new adhesive tape from your new lens, and apply to the camera side only.
  6. Canon EOS 5D Mark II LCD Window Replacement: 步骤 6 中的图像 1,1
    • Once lined up apply pressure around the sticker until the tape is firmly in place
  7. Canon EOS 5D Mark II LCD Window Replacement: 步骤 7 中的图像 1,1
    • Now remove the backing of the adhesive.
  8. Canon EOS 5D Mark II LCD Window Replacement: 步骤 8 中的图像 1,1
    • Remove the protective film from the screen and apply to your camera. Make sure everything is lined up, and placed properly.
  9. Canon EOS 5D Mark II LCD Window Replacement: 步骤 9 中的图像 1,1
    • You now have a camera that looks like it just came out of the box!
结论
14等其他人完成本指南。
Hans Bruch jr
于02/27/11注册
937 声望
创作了3篇指南
8指南评论
Thank you for making this guide, it helped me fix my camera!
Randy
randydellinger - 回复
Um, that's a window, not a lens.
TechnicianExtraordinaire - 回复
Sarcasm I hope?
Josh Forester -
Great guide, thank you for posting it. Fixed my 5DM2 in under 5 minutes!
Chris Haswell - 回复
But where do i buy the windowglas?
gjertrudgrimsbo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 114
总计 69,633
