跳转到主内容
Canon EOS 5D Mark II Front Panel Replacement
你所需要的
  1. Canon EOS 5D Mark II Front Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
  2. Canon EOS 5D Mark II Front Panel Replacement: 步骤 2 中的图像 1,1
    • Remove both 5.4 mm screws using a Phillips #0.
    I just accidentally stripped one of those screws. Is there anything I can do or am I...screwed?
    Casey Ayers - 回复
  3. Canon EOS 5D Mark II Front Panel Replacement: 步骤 3 中的图像 1,1
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
    Before removing the port cover, you must also remove the screw to the left of the mic jack and the screw below the HDMI port.
    Teovall - 回复
  4. Canon EOS 5D Mark II Front Panel Replacement: 步骤 4 中的图像 1,1
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
    It is important to remove the diopter adjustment screw and the diopter wheel above the right screw. Otherwise you will not be able to take off the top panel in step 22.
    Per Feet - 回复
    Use Phillips #00 screwdriver.
    Mr Blueeye - 回复
  5. Canon EOS 5D Mark II Front Panel Replacement: 步骤 5 中的图像 1,1
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
    The screw on the left side of this photo is shorter than the other two.
    rakurai - 回复
  6. Canon EOS 5D Mark II Front Panel Replacement: 步骤 6 中的图像 1,1
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
  7. Canon EOS 5D Mark II Front Panel Replacement: 步骤 7 中的图像 1,1
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
  8. Canon EOS 5D Mark II Front Panel Replacement: 步骤 8 中的图像 1,1
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
  9. Canon EOS 5D Mark II Front Panel Replacement, Front Panel: 步骤 9 中的图像 1,1
    • Using tweezers, pull out the wire attaching the front panel to the motherboard.
  10. Canon EOS 5D Mark II Front Panel Replacement: 步骤 10 中的图像 1,1
    • Peel off the rubber cover on the front panel in order to access the screws underneath.
  11. Canon EOS 5D Mark II Front Panel Replacement: 步骤 11 中的图像 1,1
    • Remove each of the 4.9 mm three screws using a Phillips #0.
  12. Canon EOS 5D Mark II Front Panel Replacement: 步骤 12 中的图像 1,1
    • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
  13. Canon EOS 5D Mark II Front Panel Replacement: 步骤 13 中的图像 1,1
    • Remove the single screw underneath where the lens would be using a Phillips #0.
  14. Canon EOS 5D Mark II Front Panel Replacement: 步骤 14 中的图像 1,3 Canon EOS 5D Mark II Front Panel Replacement: 步骤 14 中的图像 2,3 Canon EOS 5D Mark II Front Panel Replacement: 步骤 14 中的图像 3,3
    • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
  15. Canon EOS 5D Mark II Front Panel Replacement: 步骤 15 中的图像 1,2 Canon EOS 5D Mark II Front Panel Replacement: 步骤 15 中的图像 2,2
    • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
    You need to remove the in/out port side panel first. There are two screws next to the mic in and below the HDMI out ports to remove.
    Radian - 回复
结论
12等其他人完成本指南。
Mike Seed
于09/22/14注册
2,956 声望
创作了8篇指南
团队
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G6
3 名成员
创作了16篇指南
一条评论
Good write-up. I just replaced my casing using these instructions.
sebastien - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 47
总计 10,998
