简介
This guide will show users how to remove the front panel. It is necessary to remove the front panel in order to remove the top panel and access many internal components.
你所需要的
Remove both 5.4 mm screws using a Phillips #0.
I just accidentally stripped one of those screws. Is there anything I can do or am I...screwed?
Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
12等其他人完成本指南。
