跳转到主内容
Canon EOS 5D Mark II Clock Battery Replacement
你所需要的
  1. Canon EOS 5D Mark II Clock Battery Replacement, Clock Battery: 步骤 1 中的图像 1,1
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Clock Battery Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #000, remove the single 3.4 mm screw.
  3. Canon EOS 5D Mark II Clock Battery Replacement: 步骤 3 中的图像 1,1
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
结论
16等其他人完成本指南。
Mike Seed
于09/22/14注册
3,115 声望
创作了8篇指南
团队
USF Tampa, Team 1-6, Hickman Fall 2014 USF Tampa, Team 1-6, Hickman Fall 2014 的会员
USFT-HICKMAN-F14S1G6
3 名成员
创作了17篇指南
4指南评论
This Battery for Clock only? or CMos and Personal setting to?
there has to be something to retain all these settings once the main battery pack goes dead and or is removed from the camera?
My User 1 Pictures styles wont Save? it'll save but once i turn off My Canon Eos 5D Mark II and then back on again, my Color /Contrast/Sharpness are all Dead Center/= back to Default AGAIN? :/
Any Help here?
THANK YOU,
Greg - 回复
I did not write the original post, but I believe once you remove this battery ALL custom changes and time will be gone. You will have to re-create them. Besides the rechargeable battery, the only one keeping track of some settings is this one.
CL
Carlos Lijeron - 回复
Will doing this reset the shutter count in the camera? Like when you go to an external program to see how many shutter actuations there have been over the lifetime of the camera, will that number be erased?
Tom Fewchuk - 回复
No, because some faulty behavior i removed my clock battery from my 5D MK2, but the shutter count is still the same, it would be to easy to hack a camera to be sold on a good price. :)
Vass János Szilárd -
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 32
过去 30 天: 154
总计 28,097
