简介
Use this guide to remove the back panel in order to access the LCD, buttons, speaker, and other parts.
你所需要的
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
15等其他人完成本指南。
2指南评论
I had a loose back panel on my EOS 5d and your pictures and instructions gave me the courage to peel back the rubber and tighten screw (was out of its hole) and viola. No more squeak. Thanks so much for your pictorial. Best, John M
jdmiller41 - 回复
