简介
An Error 99 is an non specific error which means that camera doesn't know or have a code for the problem. In my case the shutter assembly needed replacing. This was a fairly involved process for a beginner such as myself.
This is not a comprehensive guide but should be used in conjunction with the Canon Service Manual and youtube videos. I hope that some of the pictures I took along the way might help you identify or remember how each step works.
  1. Get the Canon 40D Service Repair Manual
    • Get the Canon 40D Service Repair Manual
    • Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
    • Watch a couple Youtube videos on this process
  2. Peel off rubber grips Peel off rubber grips
    • Peel off rubber grips
  3. take off front piece
    • take off front piece
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. take off rear connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
    • take off rear
    • connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
  6. Take off top cover Take off top cover Take off top cover
    • Take off top cover
  7. take off bottom plate disconnect and remove bottom board disconnect and remove bottom board
    • take off bottom plate
    • disconnect and remove bottom board
  8. remove CMOS assembly
    • remove CMOS assembly
  9. remove metal back
    • remove metal back
    • remove and replace shutter assembly, transfering components that aren't on the new one
结论
5等其他人完成本指南。
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
wareibevictoriap - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 8
过去的30天: 59
总计 4,470
