跳转到主内容
Canon EOS 40D Date and Time Battery Replacement
你所需要的
  1. Canon EOS 40D Date and Time Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Date and Time Battery Replacement: 步骤 2 中的图像 1,1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Date and Time Battery Replacement: 步骤 3 中的图像 1,1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 步骤 4 中的图像 1,3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 步骤 4 中的图像 2,3 Canon EOS 40D Date and Time Battery Replacement, Date and Time Battery: 步骤 4 中的图像 3,3
    • Remove the date and time battery holder by sliding it out of the slot.
  5. Canon EOS 40D Date and Time Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the date and time battery from the battery holder.
结论
10等其他人完成本指南。
Doug Kruse
于09/03/15注册
788 声望
创作了3篇指南
团队
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G3
4 名成员
创作了16篇指南
6指南评论
Thank you. This is fantastic information that is *not* in the manual. I bought an unnecessary main battery, but this resuscitated my camera on a trip.
Thanks! David D.
David Drinkwater - 回复
All the other advice I found says to remove two screws, when it's really as simple as you show here. Thanks!
Stephen Spratley - 回复
This was so helpful, thank you! Also if you are in a jam and do not have a CR2016, you can use a CR2032 directly without using the normal battery tray.
paniak - 回复
Great help! Accurate, easy to follow directions
Jack Applegate - 回复
Excellent. Just what I needed, to bring life back to the dead.
pvlewisnz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 130
总计 16,899
