跳转到主内容
修复你的物品
维修的权力
商店
简介
Taking off the top of the camera allows repair access to the eye piece and command dial.
配件
没有特定配件。
  1. Open up the battery door. Open up the battery door. Open up the battery door.
    • Open up the battery door.
  2. Remove the batteries from the camera by sliding them out into your palm. Remove the batteries from the camera by sliding them out into your palm.
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Release the side latch to open the back panel. Release the side latch to open the back panel.
    • Release the side latch to open the back panel.
  4. Remove the two black 4.5mm screws above and below the latch. Remove the two black 4.5mm screws above and below the latch.
    • Remove the two black 4.5mm screws above and below the latch.
  5. Using your finger, carefully pry open the side panel from the top of camera. Pull panel downwards to remove.
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Remove the two silver 6mm Phillips #1 screws. Remove the two silver 6mm Phillips #1 screws.
    • Remove the two silver 6mm Phillips #1 screws.
  7. Flip camera over to the bottom. Remove the one 5mm Phillips #1 silver screw.
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  9. Remove the front panel by pulling away from the side with the lever. Remove the front panel by pulling away from the side with the lever.
    • Remove the front panel by pulling away from the side with the lever.
  10. Remove three black 7.3mm Phillips #1 screws located on the corners of the camera. Remove five black 4.8mm Phillips #1 screws.
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  11. Simply remove the bottom panel by prying it off with your finger. When removing the panel, be sure the bottom of the camera is facing upright.  There are loose gears that may fall out. Be wary of a loose piece of foam attached to the bottom panel.
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  12. Remove the remote control socket cover. Remove the remote control socket cover. Remove the remote control socket cover.
    • Remove the remote control socket cover.
  13. Remove two black 4.5mm Phillips #1 screws. Remove two black 4.5mm Phillips #1 screws.
    • Remove two black 4.5mm Phillips #1 screws.
  14. Remove two black 4.8mm Phillips #1 screws on the front of the camera. Remove two black 4.8mm Phillips #1 screws on the front of the camera.
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  15. Pry open the side grip using a spudger. Pry open the side grip using a spudger.
    • Pry open the side grip using a spudger.
  16. With your hands, remove the rubber grip from the eye piece. With your hands, remove the rubber grip from the eye piece.
    • With your hands, remove the rubber grip from the eye piece.
  17. Remove the eyecup from the eyepiece by pushing the eyecup up.
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  18. Remove two silver 5.0mm Phillips #1 screws. Remove two silver 5.0mm Phillips #1 screws.
    • Remove two silver 5.0mm Phillips #1 screws.
  19. Remove the silver 5.5mm Phillips #1 screw.
    • Remove the silver 5.5mm Phillips #1 screw.
  20. Pry the top silver part of the camera off. Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
结论
另外一个人完成了本指南。
Tammy Kong
于2014年01月23日注册
726 信誉积分
创作了6篇指南
团队
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G20
4 名成员
创作了21篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 423
