跳转到主内容
加入维修社区 - 创建账户
Canon EOS 300 Top Panel Replacement
你所需要的
  1. Canon EOS 300 Top Panel Replacement, Batteries: 步骤 1 中的图像 1,3 Canon EOS 300 Top Panel Replacement, Batteries: 步骤 1 中的图像 2,3 Canon EOS 300 Top Panel Replacement, Batteries: 步骤 1 中的图像 3,3
    • Open up the battery door.
  2. Canon EOS 300 Top Panel Replacement: 步骤 2 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Top Panel Replacement, Side Panel with Lever: 步骤 3 中的图像 1,2 Canon EOS 300 Top Panel Replacement, Side Panel with Lever: 步骤 3 中的图像 2,2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Top Panel Replacement: 步骤 4 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 4 中的图像 2,2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Top Panel Replacement: 步骤 5 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 5 中的图像 2,2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Top Panel Replacement, Front Panel: 步骤 6 中的图像 1,2 Canon EOS 300 Top Panel Replacement, Front Panel: 步骤 6 中的图像 2,2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Top Panel Replacement: 步骤 7 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 7 中的图像 2,2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Top Panel Replacement: 步骤 8 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 8 中的图像 2,2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Top Panel Replacement, Bottom Panel: 步骤 9 中的图像 1,2 Canon EOS 300 Top Panel Replacement, Bottom Panel: 步骤 9 中的图像 2,2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Top Panel Replacement: 步骤 10 中的图像 1,3 Canon EOS 300 Top Panel Replacement: 步骤 10 中的图像 2,3 Canon EOS 300 Top Panel Replacement: 步骤 10 中的图像 3,3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Top Panel Replacement, Side Panel with Grip: 步骤 11 中的图像 1,3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: 步骤 11 中的图像 2,3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: 步骤 11 中的图像 3,3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Top Panel Replacement: 步骤 12 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 12 中的图像 2,2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Top Panel Replacement: 步骤 13 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 13 中的图像 2,2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Top Panel Replacement: 步骤 14 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 14 中的图像 2,2
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Top Panel Replacement, Eyecup: 步骤 15 中的图像 1,2 Canon EOS 300 Top Panel Replacement, Eyecup: 步骤 15 中的图像 2,2
    • With your hands, remove the rubber grip from the eye piece.
  16. Canon EOS 300 Top Panel Replacement: 步骤 16 中的图像 1,1
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  17. Canon EOS 300 Top Panel Replacement, Top Panel: 步骤 17 中的图像 1,2 Canon EOS 300 Top Panel Replacement, Top Panel: 步骤 17 中的图像 2,2
    • Remove two silver 5.0mm Phillips #1 screws.
  18. Canon EOS 300 Top Panel Replacement: 步骤 18 中的图像 1,1
    • Remove the silver 5.5mm Phillips #1 screw.
  19. Canon EOS 300 Top Panel Replacement: 步骤 19 中的图像 1,2 Canon EOS 300 Top Panel Replacement: 步骤 19 中的图像 2,2
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
结论
3等其他人完成本指南。
Tammy Kong
于01/23/14注册
805 声望
创作了6篇指南
团队
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G20
4 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 52
总计 1,188
