当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Make sure to keep track of the small black piece of rubber under the latch.
Simply remove the bottom panel by prying it off with your finger.
When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
Be wary of a loose piece of foam attached to the bottom panel.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
