跳转到主内容
Canon EOS 300 Back Lock-Release Lever Replacement
你所需要的
  1. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: 步骤 1 中的图像 1,3 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: 步骤 1 中的图像 2,3 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: 步骤 1 中的图像 3,3
    • Open up the battery door.
  2. Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 2 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 2 中的图像 2,2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: 步骤 3 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: 步骤 3 中的图像 2,2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 4 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 4 中的图像 2,2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 5 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 5 中的图像 2,2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: 步骤 6 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: 步骤 6 中的图像 2,2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 7 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 7 中的图像 2,2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 8 中的图像 1,2 Canon EOS 300 Back Lock-Release Lever Replacement: 步骤 8 中的图像 2,2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: 步骤 9 中的图像 1,3 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: 步骤 9 中的图像 2,3 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: 步骤 9 中的图像 3,3
    • Pull off the lever by pushing up from the bottom and pulling away from the bottom.
结论
2等其他人完成本指南。
Jordan Tang
于01/24/14注册
590 声望
创作了5篇指南
团队
Cal Poly, Team 6-20, Maness Winter 2014 Cal Poly, Team 6-20, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G20
4 名成员
创作了32篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 22
总计 1,657
