跳转到主内容
加入维修社区 - 创建账户
Canon EOS 30 Top Panel Replacement
你所需要的
  1. Canon EOS 30 Top Panel Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Top Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Top Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Top Panel Replacement: 步骤 4 中的图像 1,1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 Top Panel Replacement, Top Panel: 步骤 5 中的图像 1,1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 Top Panel Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 Top Panel Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 Top Panel Replacement: 步骤 8 中的图像 1,2 Canon EOS 30 Top Panel Replacement: 步骤 8 中的图像 2,2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 50
总计 3,670
