当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the outer eyepiece upward to remove it.
Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward.
Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
Remove two 5.9 mm silver screws on top of camera to detach left strap loop (opposite grip).
Remove one 8.5 mm silver screw (front) and one 5.45 mm silver screw (back) to remove strap loop near LCD screen.
取消:我没有完成这个指南。
2等其他人完成本指南。
与6其他贡献者
于04/17/11注册
15 声望
撰写一个指南
徽章: 6
+ 3更多徽章
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 19
总计 2,630
