跳转到主内容
Canon EOS 30 Lens Mount Rings
你所需要的
  1. Canon EOS 30 Lens Mount Rings, Front Panel: 步骤 1 中的图像 1,1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 Lens Mount Rings: 步骤 2 中的图像 1,1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 Lens Mount Rings: 步骤 3 中的图像 1,1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 Lens Mount Rings: 步骤 4 中的图像 1,1
    • Remove the front panel by lifting it away from the camera's body.
    I need a video tutorial
    Abdullah dicky S - 回复
  5. Canon EOS 30 Lens Mount Rings, Lens Mount Rings: 步骤 5 中的图像 1,1
    • Remove four 7.1 mm silver screws from lens mount ring.
  6. Canon EOS 30 Lens Mount Rings: 步骤 6 中的图像 1,1
    • Remove outer mount ring.
    • The silver button may detach.
  7. Canon EOS 30 Lens Mount Rings: 步骤 7 中的图像 1,1
    • Remove thin gold ring.
    • Correct orientation is pictured.
  8. Canon EOS 30 Lens Mount Rings: 步骤 8 中的图像 1,1
    • Remove thin silver ring.
结论
另外一个人完成了本指南。
Antonia
于04/17/11注册
124 声望
创作了2篇指南
团队
Cal Poly, Team 8-8, Regan Spring 2011 Cal Poly, Team 8-8, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
1指南评论
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
Patryk Granatowicz - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 41
总计 5,697
