当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
Slide the outer eyepiece upward to remove it.
Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward.
Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
Remove two 6.5 mm black screws from the panel.
Remove the plastic remote control socket cap by pulling it straight out.
Slide the panel toward the bottom of the camera to remove.
Remove the single 4.8 silver screw from the control socket.
The control socket is now secure by three wires.
Desolder connections to replace the remote control socket.
Remove the two 5.5 mm screws from front of camera.
Remove grip panel.
取消:我没有完成这个指南。
与8其他贡献者
于04/17/11注册
236 声望
创作了3篇指南
徽章: 8
+ 5更多徽章
CPSU-REGAN-S11S8G8
5 名成员
创作了22篇指南
Didn't you forget the step to remove the bottom plate?
Sino Lino - 2020年3月31日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,758
