跳转到主内容
工具
配件
没有特定配件。
  1. Canon EOS 20D Rear Case Replacement, Remove the eyepiece cap: 步骤 1 中的图像 1,2 Canon EOS 20D Rear Case Replacement, Remove the eyepiece cap: 步骤 1 中的图像 2,2
    • Pull up on both sides of the the eyepiece cap. It should come off with little pressure.
  2. Canon EOS 20D Rear Case Replacement, Remove screws from under the eyepiece cap: 步骤 2 中的图像 1,1
    • Remove the two screws hidden under the viewfinder eyepiece cap.
  3. Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: 步骤 3 中的图像 1,3 Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: 步骤 3 中的图像 2,3 Canon EOS 20D Rear Case Replacement, Remove hidden screw and other visible screw: 步骤 3 中的图像 3,3
    • Peel off the rubber grip on the back by grasping one of the corners and pulling it away from the camera body.
    • Once removed, a hidden screw is revealed.
    • Remove both screws from the rear of the camera.
  4. Canon EOS 20D Rear Case Replacement, Remove bottom screws: 步骤 4 中的图像 1,1
    • Remove the two indicated screws from the bottom of the camera.
  5. Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: 步骤 5 中的图像 1,3 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: 步骤 5 中的图像 2,3 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: 步骤 5 中的图像 3,3
    • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
    • Flip the lock on the flex cable connector up with a spudger.
    • The front panel should pop off, now that the cable has been disconnected.
    • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
结论
2等其他人完成本指南。
Alec M
于2016年05月08日注册
1,171 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 958
