跳转到主内容
Canon ELPH Z3 Camera Rear Screen Replacement
你所需要的
  1. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: 步骤 1 中的图像 1,3 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: 步骤 1 中的图像 2,3 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: 步骤 1 中的图像 3,3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 2 中的图像 1,3 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 2 中的图像 2,3 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 2 中的图像 3,3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 3 中的图像 1,2 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 3 中的图像 2,2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 4 中的图像 1,3 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 4 中的图像 2,3 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 4 中的图像 3,3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: 步骤 5 中的图像 1,2 Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: 步骤 5 中的图像 2,2
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 6 中的图像 1,3 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 6 中的图像 2,3 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 6 中的图像 3,3
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 7 中的图像 1,2 Canon ELPH Z3 Camera Rear Screen Replacement: 步骤 7 中的图像 2,2
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
结论
Katy Skillings
于10/21/16注册
1 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 263
