跳转到主内容
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: 步骤 1 中的图像 1,3 Canon ELPH Z3 Camera Battery  Replacement, Battery: 步骤 1 中的图像 2,3 Canon ELPH Z3 Camera Battery  Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: 步骤 2 中的图像 1,2 Canon ELPH Z3 Camera Battery  Replacement: 步骤 2 中的图像 2,2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
结论
Nathan Barros
于10/18/16注册
1 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-7, Catania Fall 2016 UMass Dartmouth, Team 1-7, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G7
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 22
总计 874
