当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
The first set of screws is located on the front and bottom of the lens casing.
Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
Remove the lens casing by pulling it away from the body of the camera.
Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
Pull the SLR lens mount away from the body of the camera.
Be aware that a pin will fall out when the SLR lens mount is removed.
取消:我没有完成这个指南。
6等其他人完成本指南。
与9其他贡献者
于10/04/11注册
213 声望
撰写一个指南
徽章: 8
+ 5更多徽章
UWSTOUT-ZHOU-F11S5G1
3 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 64
总计 11,727
