跳转到主内容
Canon AE-1 SLR Lens Mount Replacement
你所需要的
  1. Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: 步骤 1 中的图像 1,2 Canon AE-1 SLR Lens Mount Replacement, SLR Lens Mount: 步骤 1 中的图像 2,2
    • Remove the first set of two screws from the lens outer casing using a Phillips #00 screwdriver.
    • The first set of screws is located on the front and bottom of the lens casing.
  2. Canon AE-1 SLR Lens Mount Replacement: 步骤 2 中的图像 1,2 Canon AE-1 SLR Lens Mount Replacement: 步骤 2 中的图像 2,2
    • Remove the remaining two screws from the right and left sides of the lens outer casing using a Phillips #00 screwdriver.
  3. Canon AE-1 SLR Lens Mount Replacement: 步骤 3 中的图像 1,1
    • Remove the lens casing by pulling it away from the body of the camera.
  4. Canon AE-1 SLR Lens Mount Replacement: 步骤 4 中的图像 1,1
    • Remove the four #00 screws from the SLR lens mount using a Phillips #00 screwdriver.
  5. Canon AE-1 SLR Lens Mount Replacement: 步骤 5 中的图像 1,3 Canon AE-1 SLR Lens Mount Replacement: 步骤 5 中的图像 2,3 Canon AE-1 SLR Lens Mount Replacement: 步骤 5 中的图像 3,3
    • Pull the SLR lens mount away from the body of the camera.
    • Be aware that a pin will fall out when the SLR lens mount is removed.
结论
6等其他人完成本指南。
Joe Blumberg
于10/04/11注册
213 声望
撰写一个指南
团队
UW Stout, Team 5-1, Zhou Fall 2011 UW Stout, Team 5-1, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 50
总计 11,833
