当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Open the film compartment by pulling on the release pin.
Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
Then use Isopropyl Alcohol to assist in removing the old light filter foam.
Placing light filter foam improperly could result in light exposure on film.
Cut the new light filter foam to size so it can fit in the slot.
Place the sticky side of the new strip of light filter foam over old foams location.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
