跳转到主内容
加入维修社区 - 创建账户
Canon AE-1 Light Filter Foam Replacement
你所需要的
  1. Canon AE-1 Light Filter Foam Replacement, Light Filter Foam: 步骤 1 中的图像 1,1
    • Open the film compartment by pulling on the release pin.
    • Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
    • Then use Isopropyl Alcohol to assist in removing the old light filter foam.
  2. Canon AE-1 Light Filter Foam Replacement: 步骤 2 中的图像 1,1
    • Placing light filter foam improperly could result in light exposure on film.
    • Cut the new light filter foam to size so it can fit in the slot.
    • Place the sticky side of the new strip of light filter foam over old foams location.
结论
To reassemble your device, follow these instructions.
2等其他人完成本指南。
Brad
于10/04/11注册
47 声望
撰写一个指南
团队
UW Stout, Team 5-1, Zhou Fall 2011 UW Stout, Team 5-1, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G1
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 47
总计 14,000
