跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will show you how to replace your square port by unscrewing the plastic casing that holds it, unpeeling the ribbon cable that attaches it to the case, and unplugging one end of the ribbon cable that will free the entire port.
配件
没有特定配件。
  1. Slide the plastic opening tool under the plastic to unpeel it from the glass. Gently pry the plastic framing from the glass. Repeat on the other side.
    • Slide the plastic opening tool under the plastic to unpeel it from the glass.
    • Gently pry the plastic framing from the glass.
    • Repeat on the other side.
  2. Remove the front plastic frame. Remove the front plastic frame.
    • Remove the front plastic frame.
  3. Wedge the plastic opening tool under the glass and pull up. Slide the glass forward. Remove the glass.
    • Wedge the plastic opening tool under the glass and pull up.
    • Slide the glass forward.
    • Remove the glass.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Unscrew the three screws that attach the grey plastic shell to the case. Unscrew the three screws that attach the grey plastic shell to the case. Unscrew the three screws that attach the grey plastic shell to the case.
    • Unscrew the three screws that attach the grey plastic shell to the case.
  6. Remove the shell from the inner square port. Remove the shell from the inner square port. Remove the shell from the inner square port.
    • Remove the shell from the inner square port.
  7. Gently unpeel the ribbon cable from the bottom of the case. Gently unpeel the ribbon cable from the bottom of the case. Gently unpeel the ribbon cable from the bottom of the case.
    • Gently unpeel the ribbon cable from the bottom of the case.
  8. Unplug the ribbon cable.
    • Unplug the ribbon cable.
    • Remove the square port.
结论
Shannon
于2013年10月28日注册
340 信誉积分
创作了2篇指南
团队
Clemson, Team 1-89, Diaz Fall 2013 Clemson, Team 1-89, Diaz Fall 2013 的会员
CLEM-DIAZ-F13S1G89
1 名成员
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 567
