简介
To replace the scanner bar, the glass must first be removed, and then the scanner bar can be easily removed and replaced.
你所需要的
Slide plastic opening tool under the plastic.
Gently pry the plastic framing off the glass.
Repeat on the other side.
2等其他人完成本指南。
一条评论
Hello Nick, thank you for the guide.
My CanoScan LiDE 220 has started to introduce a line down the middle of the page when I scan with VueScan. Not sure if this guide applies.
Mark Leung - 回复
