简介
This guide is a quick solution to fix worn out roller skate wheels! Rather than spend lots of money on a new pair, just replace your old wheels to get your roller skates spinning smoothly again!
你所需要的
Use a 13mm wrench to loosen the nuts in the center of the wheel(s) that need to be replaced.
Remove the nuts from the axel.
即将完成!
This is a simple replacement with very easy-to-follow instructions. If you followed all the steps exactly, you will be skating again in no time!
结论
