简介
In order to complete this repair properly, you will need teflon tape to seal the threads of the thumb screw drain. Although this step seems unnecessary in some cases, it will make your compressor run more efficiently without excessive starting and stopping. The replacement of thumb screw drain is straightforward.
你所需要的
Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
即将完成!
结论
