跳转到主内容
Campbell Hausfeld FP204800 Thumb Screw Drain Replacement
你所需要的
  1. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Remove Thumb Screw Drain: 步骤 1 中的图像 1,1
    • Remove the thumb screw drain from the bottom of the compressor using a Smart Wrench.
    • The thumb screw may not easily be removed due to corrosion.
  2. Campbell Hausfeld FP204800 Thumb Screw Drain Replacement, Apply Teflon Tape: 步骤 2 中的图像 1,1
    • Apply teflon tape to the replacement thumb screw drain.
    • The teflon tape should be wound tightly around the entire threaded portion of the thumb screw drain.
    • When you reassemble the thumb screw drain on the compressor, make sure to fully tighten it using a Smart Wrench.
结论
Eric
于10/09/14注册
409 声望
创作了3篇指南
团队
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G29
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 375
