跳转到主内容
Campbell Hausfeld FP204800 Safety Valve Replacement
你所需要的
  1. Campbell Hausfeld FP204800 Safety Valve Replacement, Remove Safety Valve: 步骤 1 中的图像 1,1
    • Using the medium crescent wrench, unscrew the safety valve by twisting it counter-clockwise.
    • The safety valve may be difficult to unscrew because of corrosion.
  2. Campbell Hausfeld FP204800 Safety Valve Replacement, Apply Teflon Tape to Safety Valve: 步骤 2 中的图像 1,1
    • Apply teflon tape to the replacement safety valve.
    • The teflon tape should be wound tightly around the entire threaded portion of the safety valve.
结论
Eric
于10/09/14注册
409 声望
创作了3篇指南
团队
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G29
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 412
