跳转到主内容
Campbell Hausfeld FP204800 Pressure Gauge Replacement
你所需要的
  1. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: 步骤 1 中的图像 1,3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: 步骤 1 中的图像 2,3 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud Screws: 步骤 1 中的图像 3,3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: 步骤 2 中的图像 1,2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove Shroud: 步骤 2 中的图像 2,2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: 步骤 3 中的图像 1,1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the On/Off Switch Wiring: 步骤 4 中的图像 1,1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: 步骤 5 中的图像 1,2 Campbell Hausfeld FP204800 Pressure Gauge Replacement, Remove the pressure gauges: 步骤 5 中的图像 2,2
    • Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
结论
2等其他人完成本指南。
Eric
于10/09/14注册
409 声望
创作了3篇指南
团队
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G29
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 22
总计 993
