跳转到主内容
Campbell Hausfeld FP204800 On/Off Switch Replacement
你所需要的
  1. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: 步骤 1 中的图像 1,3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: 步骤 1 中的图像 2,3 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud Screws: 步骤 1 中的图像 3,3
    • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  2. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: 步骤 2 中的图像 1,2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove Shroud: 步骤 2 中的图像 2,2
    • Remove the plastic shroud from the compressor.
    • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  3. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: 步骤 3 中的图像 1,1
    • Gently pull the wire attached from the pressure switch to the on/off switch.
    • It should come off the pressure switch with ease.
    • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
  4. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the On/Off Switch Wiring: 步骤 4 中的图像 1,1
    • Gently pull the wire connected from the on/off switch to the motor of the compressor.
    • It should be the only wire keeping the shroud from being lifted from the compressor.
  5. Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: 步骤 5 中的图像 1,2 Campbell Hausfeld FP204800 On/Off Switch Replacement, Configure the on/off switch for removal: 步骤 5 中的图像 2,2
    • Twist the On/Off switch from the underside of the shroud.
    • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
    • When the switch has reached the correct position, you will feel it "click" into place.
  6. Campbell Hausfeld FP204800 On/Off Switch Replacement, Remove the on/off switch: 步骤 6 中的图像 1,1
    • Push the on/off switch from the underside of the shroud until it comes loose.
    • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
结论
另外一个人完成了本指南。
Caleb Davies
于10/07/14注册
528 声望
创作了4篇指南
团队
Cal Poly, Team 14-29, Maness Fall 2014 Cal Poly, Team 14-29, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G29
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,478
