跳转到主内容
Cambridge SoundWorks OontZ Angle Plus Speakers Replacement
你所需要的
  1. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Rubber Casing: 步骤 1 中的图像 1,1
    • Remove the six screw covers from the bottom of the device.
  2. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 2 中的图像 1,1
    • Starting from the screw covers, remove the front and back casing of the device.
  3. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 3 中的图像 1,1
    • Carefully pull off the casing covering the ends.
  4. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 4 中的图像 1,1
    • Slowly remove the casing from the top of the device.
  5. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speaker Grill: 步骤 5 中的图像 1,1
    • Unscrew the five 11.5mm Phillips screws from the bottom plate.
  6. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 6 中的图像 1,1
    • Carefully pull apart the bottom and top plates, using the blue plastic opening tool.
  7. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 7 中的图像 1,1
    • Once the plates are separated, slowly pull the bottom plate away from the top plate.
    • There are wires connected to both plates, so be cautious while doing this step.
  8. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 8 中的图像 1,1
    • Use the metal spudger to bend the three bendable clamps on the ends of the speaker cover.
    • Beware, the bending process requires patience and extra time.
  9. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 9 中的图像 1,1
    • Next, use the metal spudger to bend the four bendable clamps on the bottom of the speaker cover.
    • This step also requires some time and patience.
  10. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 10 中的图像 1,2 Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 10 中的图像 2,2
    • Finally, bend the speaker cover upward and it will slide out.
  11. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement, Speakers: 步骤 11 中的图像 1,1
    • With some force, push the motherboard straight in toward the center of the device.
  12. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 12 中的图像 1,1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This makes the motherboard fit in the groove rather tight.
  13. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 13 中的图像 1,1
    • Unplug the speaker's connector from the motherboard.
  14. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 14 中的图像 1,1
    • Unscrew the eight screws holding the speakers in place.
  15. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 15 中的图像 1,1
    • Desolder the the wires connected to the back side of both speakers.
  16. Cambridge SoundWorks OontZ Angle Plus Speakers Replacement: 步骤 16 中的图像 1,1
    • Carefully push the speakers out one at a time.
结论
David Rice
于02/10/16注册
161 声望
撰写一个指南
团队
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 的会员
USFT-NANCE-S16S1G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 1,900
