跳转到主内容
Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
你所需要的
  1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 步骤 1 中的图像 1,2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: 步骤 1 中的图像 2,2
    • Pull back the six screw covers on the bottom of the device.
    • Starting from the screw covers, peel the casing away from the bottom plate.
  2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: 步骤 2 中的图像 1,1
    • Unscrew the five 11.5mm Phillips screws on the bottom plate.
  3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 3 中的图像 1,1
    • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
  4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 4 中的图像 1,1
    • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
    • There are wires connected to both plates so do this step with care.
  5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
    • Remove the brace that holds the battery in place.
  6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 6 中的图像 1,1
    • Separate the battery from the bottom plate and set the bottom plate aside.
  7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 7 中的图像 1,1
    • With some force, push the motherboard straight in toward the center of the device.
  8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 8 中的图像 1,1
    • Pull the motherboard straight out of the device.
    • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
  9. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 9 中的图像 1,1
    • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
  10. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Unplug the wires that connect the speakers to the motherboard.
  11. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 11 中的图像 1,1
    • Unplug the thin white cable connected to the buttons.
  12. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 12 中的图像 1,2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: 步骤 12 中的图像 2,2
    • Desolder the wires that connect the LED to the motherboard.
结论
团队
USF Tampa, Team 1-1, Nance Spring 2016 USF Tampa, Team 1-1, Nance Spring 2016 的会员
USFT-NANCE-S16S1G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,859
