跳转到主内容
Cambridge Audio A3i Power Cord and Transformer Replacement
你所需要的
  1. Cambridge Audio A3i Power Cord and Transformer Replacement, Case: 步骤 1 中的图像 1,1
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Power Cord and Transformer Replacement: 步骤 2 中的图像 1,1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Power Cord and Transformer Replacement: 步骤 3 中的图像 1,2 Cambridge Audio A3i Power Cord and Transformer Replacement: 步骤 3 中的图像 2,2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Power Cord and Transformer Replacement: 步骤 4 中的图像 1,1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Power Cord and Transformer Replacement, Power Cord and Transformer: 步骤 5 中的图像 1,1
    • Carefully de-solder ends of power cord from circuit board.
    • Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
    • Finally, pull the power cord through the rear panel to completely remove it.
  6. Cambridge Audio A3i Power Cord and Transformer Replacement: 步骤 6 中的图像 1,1
    • To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
    • Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
结论
5等其他人完成本指南。
Colby
于04/15/10注册
338 声望
创作了3篇指南
团队
Cal Poly, Team 28-36, Regan Spring 2010 Cal Poly, Team 28-36, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G36
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 20
总计 7,128
