当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove 3 screws on bottom of case.
Remove 13 screws on rear panel.
Do not move the rear panel too far, as the power cord is still connected.
Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
It may require some wiggling, but it should slip out of the hole and then off of the cord.
With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
Be sure to hold the motherboard with one hand while removing the mount screws.
Unscrew ground wire from main case.
De solder 4 wires coming from transformer.
The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
