跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide describes the steps necessary to replace the motherboard of the system. This board contains the circuitry for the amplification, power, and output.
  1. Remove 2 screws from each side of the amplifier.
    • Remove 2 screws from each side of the amplifier.
  2. Remove 2 screws on rear of device. Slide top cover up and back from main case.
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Remove 3 screws on bottom of case. Remove 13 screws on rear panel.
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Unscrew ground wire from main case. De solder 4 wires coming from transformer.
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
结论
另外一个人完成了本指南。
Colby
于2010年04月15日注册
284 信誉积分
创作了3篇指南
团队
Cal Poly, Team 28-36, Regan Spring 2010 Cal Poly, Team 28-36, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G36
4 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 24
总计 5,877
