跳转到主内容
简介
This guide describes the steps necessary to replace the motherboard of the system. This board contains the circuitry for the amplification, power, and output.
  1. Remove 2 screws from each side of the amplifier.
    • Remove 2 screws from each side of the amplifier.
  2. Remove 2 screws on rear of device. Slide top cover up and back from main case.
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Remove 3 screws on bottom of case. Remove 13 screws on rear panel.
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
  6. With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
  7. Unscrew ground wire from main case. De solder 4 wires coming from transformer.
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
结论
另外一个人完成了本指南。
Colby
于2010年04月15日注册
284 信誉积分
创作了3篇指南
团队
Cal Poly, Team 28-36, Regan Spring 2010 Cal Poly, Team 28-36, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G36
4 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 11
总计 5,890
