跳转到主内容
Calculator is Stuck While Graphing
  1. Calculator is Stuck While Graphing, Calculator is Stuck While Graphing: 步骤 1 中的图像 1,1
    • To cancel the graphing process, press the "ON" button.
  2. Calculator is Stuck While Graphing: 步骤 2 中的图像 1,3 Calculator is Stuck While Graphing: 步骤 2 中的图像 2,3 Calculator is Stuck While Graphing: 步骤 2 中的图像 3,3
    • Go to "Zoom." Navigate to and highlight "ZoomFit" then press "Enter." Doing so will automatically set your graphing window to the most appropriate dimensions.
  3. Calculator is Stuck While Graphing: 步骤 3 中的图像 1,1
    • If you are graphing complex equations, multiple equations, or a combination of the two, it may take anywhere from 1 minute to 5 minutes to graph.
    • The bar on the top right corner indicates the calculator is graphing.
  4. Calculator is Stuck While Graphing: 步骤 4 中的图像 1,2 Calculator is Stuck While Graphing: 步骤 4 中的图像 2,2
    • If you feel that your graph is taking too long, you can change the step resolution to a bigger number. To do so, press "Window" and change "Xres" to a value between 1 and 8. A bigger Xres value will graph more quickly.
结论
It is always a good idea to make sure your graph will display a good window.
John Baek
于09/27/12注册
31 声望
创作了4篇指南
团队
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G52
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 28
总计 1,893
