跳转到主内容
Cabinet Door Hinge Replacement
你所需要的
  1. Cabinet Door Hinge Replacement, Hinge: 步骤 1 中的图像 1,1
    • Remove the old screws to take the hinge off.
  2. Cabinet Door Hinge Replacement: 步骤 2 中的图像 1,3 Cabinet Door Hinge Replacement: 步骤 2 中的图像 2,3 Cabinet Door Hinge Replacement: 步骤 2 中的图像 3,3
    • Take the hinge off the cabinet door.
  3. Cabinet Door Hinge Replacement: 步骤 3 中的图像 1,1
    • Align the new hinge on the cabinet so that it is even and level and will open and close correctly.
  4. Cabinet Door Hinge Replacement: 步骤 4 中的图像 1,2 Cabinet Door Hinge Replacement: 步骤 4 中的图像 2,2
    • Insert and screw in the screw closest to the inside of the cabinet.
    • The innermost screw should be fastened first because it's the hardest to get to once the other screws are placed.
    • Screw in the rest of the screws until the hinge is in place.
  5. Cabinet Door Hinge Replacement: 步骤 5 中的图像 1,1
    • The hinge is now replaced and the cabinet can shut all the way.
终点
McKenna Harris
于10/23/20注册
121 声望
撰写一个指南
团队
Texas Tech, Team S9-G4, Cowan Fall 2020 Texas Tech, Team S9-G4, Cowan Fall 2020 的会员
TTU-COWAN-F20S9G4
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 37
总计 638
