跳转到主内容
Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
你所需要的
  1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: 步骤 1 中的图像 1,2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: 步骤 1 中的图像 2,2
    • The cabin air filter is located in the passenger side footwell
  2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: 步骤 2 中的图像 1,3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: 步骤 2 中的图像 2,3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: 步骤 2 中的图像 3,3
    • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
    • Once that the screws are removed, the cover will come down.
  3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: 步骤 3 中的图像 1,3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: 步骤 3 中的图像 2,3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: 步骤 3 中的图像 3,3
    • Now with more room to remove it, slide the two plastic tabs together.
    • When the two plastic tabs are in the middle pull the filter cover down.
  4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: 步骤 4 中的图像 1,2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: 步骤 4 中的图像 2,2
    • Remove the filter.
    • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
  5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: 步骤 5 中的图像 1,1
    • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
    • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
终点
4等其他人完成本指南。
由衷感谢以下译者:
es en
100%
WhoDat?正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jonatan M
于03/17/18注册
500 声望
创作了2篇指南
一条评论
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 38
过去 30 天: 162
总计 5,972
