跳转到主内容
CRKD NEO S CK24NS Button Replacement
你所需要的
  1. CRKD NEO S CK24NS Button Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Turn the CRKD NEO S CK24NS upside down with the front-facing buttons facing downward.
  2. CRKD NEO S CK24NS Button Replacement: 步骤 2 中的图像 1,3 CRKD NEO S CK24NS Button Replacement: 步骤 2 中的图像 2,3 CRKD NEO S CK24NS Button Replacement: 步骤 2 中的图像 3,3
    • Use a 1.5 mm Hex screwdriver to remove the eight 1.5 mm Hex screws from the back of the controller.
    • Carefully lift off the back panel and set it aside.
  3. CRKD NEO S CK24NS Button Replacement: 步骤 3 中的图像 1,3 CRKD NEO S CK24NS Button Replacement: 步骤 3 中的图像 2,3 CRKD NEO S CK24NS Button Replacement: 步骤 3 中的图像 3,3
    • Remove the four 2.5 mm screws holding the motherboard in place using a Phillips #0 screwdriver.
    • Take out the white plastic pieces connected to the motherboard with tweezers.
    • Gently lift the motherboard and set it aside.
    • If the small red plastic piece next to the audio jack falls out, don’t worry. You can pop it back into place during reassembly.
  4. CRKD NEO S CK24NS Button Replacement, Button: 步骤 4 中的图像 1,2 CRKD NEO S CK24NS Button Replacement, Button: 步骤 4 中的图像 2,2
    • Depending on the button(s) you want to replace, lift them out with a pair of tweezers and put the new buttons in.
    • Make sure the controller is facedown because the buttons will fall out.
结论
Kailey Sillitoe
于09/04/24注册
295 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 269
