跳转到主内容
CR-10S PRO Y Axis Linear Rail Kit Installation
你所需要的
  1. CR-10S PRO Y Axis Linear Rail Kit Installation, Machine Prep for linear rail kit: 步骤 1 中的图像 1,1
    • Remove Bed leveling knobs
    • Be careful when lifting the bed off the Y Carriage. The springs may fall when lifting the bed up.
    • Lift bed and set to the back left side of the printer
  2. CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: 步骤 2 中的图像 1,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: 步骤 2 中的图像 2,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: 步骤 2 中的图像 3,3
    • Note: uses the stock CR10S Pro Y carriage with Vslot wheels assembly to keep the rails aligned while replacing the frame bolts
    • Remove with M5X30 SHCS one at a time
    • Replace with M5X30 BHCS
    • Slide Y carriage off from the front of the machine
  3. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Prep Instructions: 步骤 3 中的图像 1,1
    • Remove from packaging
    • Note, do not touch the rail directly with your hands.
    • Wipe down rail with a lint free cloth
    • Add grease to the grease port on each side of the rail
  4. CR-10S PRO Y Axis Linear Rail Kit Installation: 步骤 4 中的图像 1,3 CR-10S PRO Y Axis Linear Rail Kit Installation: 步骤 4 中的图像 2,3 CR-10S PRO Y Axis Linear Rail Kit Installation: 步骤 4 中的图像 3,3
    • Pre-insert Spring loaded and use an Allen wrench or screwdriver to help align
    • M3 Spring loaded T-nut
    • Use the circled Rail mounting positions
    • 16x M3x8 SHCS
    • Picture with MGN guide on rail
  5. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: 步骤 5 中的图像 1,2 CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: 步骤 5 中的图像 2,2
    • Tighten the screws evenly in an X shape
    • 4x Adapter Plate
    • 16x M3x6 FHCS
  6. CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: 步骤 6 中的图像 1,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: 步骤 6 中的图像 2,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: 步骤 6 中的图像 3,3
    • Remove all Vslot wheels and bolts
    • Install endstop Trigger at this location
    • Picture 2 shows endstop Trigger install
    • M5x35 SHCS
    • 3x Stock Vslot wheel spacers
    • M5 Nylon Ring Lock Nut
  7. CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: 步骤 7 中的图像 1,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: 步骤 7 中的图像 2,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: 步骤 7 中的图像 3,3
    • Belt mounting holes goes on the right side of the priter
    • Left side screws
    • Some early kits are drilled and taped for M5 Screws. The M4x8 FHCS is substituted for a M5x10 FHCS and the M4x10 BHCS substituted for M5x10 BHCS.
    • 2x M4x8 FHCS
    • Right screw stack order
    • M4x10 BHCS - M4 washer - M4 Large OD washer
    • Tightened the left side screws first
  8. CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: 步骤 8 中的图像 1,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: 步骤 8 中的图像 2,3 CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: 步骤 8 中的图像 3,3
    • Belt Bracket Spacer
    • 2x M4x20 SHCS
  9. CR-10S PRO Y Axis Linear Rail Kit Installation, Endstop Braket mounting hardware Change: 步骤 9 中的图像 1,1
    • Remove the stock endstop bracket screw
    • Replace endstop bracket mount screw with:
    • M3x10 SHCS, M3 Washer and M3 Sliding tnut
  10. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: 步骤 10 中的图像 1,2 CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: 步骤 10 中的图像 2,2
    • M5*10 BHCS
    • Acrylic stopper
  11. CR-10S PRO Y Axis Linear Rail Kit Installation, EndStop adjustment: 步骤 11 中的图像 1,1
    • Adjust the Endstop position by sliding the endstop back until the nozzle tip lines up with the front edge of the bed when the endstop triggers.
终点
3等其他人完成本指南。
AJ Pereira
于05/29/20注册
2,735 声望
创作了16篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了41篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 83
总计 4,769
