跳转到主内容
CR-10S BL Touch Install
  1. CR-10S BL Touch Install, Disassembly: 步骤 1 中的图像 1,3 CR-10S BL Touch Install, Disassembly: 步骤 1 中的图像 2,3 CR-10S BL Touch Install, Disassembly: 步骤 1 中的图像 3,3
    • Before you begin...
    • Turn the power switch to OFF
    • Unplug the power cable
    • Using an M2 hex, remove the 5 button head screws holding the control box bottom cover on.
    • using an M2.5 hex, remove the 4 button head screws holding the power supply to the control box.
    • Lay the power supply to the side as shown.
    • Remove the grommet from the rear of the control box and pull back a few inches as shown.
  2. CR-10S BL Touch Install, Install 1a.: 步骤 2 中的图像 1,3 CR-10S BL Touch Install, Install 1a.: 步骤 2 中的图像 2,3 CR-10S BL Touch Install, Install 1a.: 步骤 2 中的图像 3,3
    • With the grommet loose, you can feed harness A through the grommet with the 2 and 3 pin connector going first.
    • Feed it through the hole in the rear of the control box.
    • Leave 4-5 inches of the loose pins and reinstall the grommet.
    • Make sure the grommet is fully seated into the hold.
  3. CR-10S BL Touch Install, Install 1b.: 步骤 3 中的图像 1,3 CR-10S BL Touch Install, Install 1b.: 步骤 3 中的图像 2,3 CR-10S BL Touch Install, Install 1b.: 步骤 3 中的图像 3,3
    • After feeding harness A into the control box, note where everything is connected in case you have remove things like the LCD connections to access the new connection points.
    • Plug in the 3 pin connector to D11 row with the red wire on the V pin. For CR-10S machines, it is the pin closest to the LCD connections.
    • Unplug the Z end stop wires from the motherboard (not shown)
    • Plug in the 2 pin connector where the original Z end stop was plugged in. This is Z- for CR-10S machines.
    • Hot glue is optional.
    • Zip tie harness A to the original harness group for strain relief.
  4. CR-10S BL Touch Install, Install 1c. Reassembly: 步骤 4 中的图像 1,3 CR-10S BL Touch Install, Install 1c. Reassembly: 步骤 4 中的图像 2,3 CR-10S BL Touch Install, Install 1c. Reassembly: 步骤 4 中的图像 3,3
    • If you're going to glue the new connections in, do it now.
    • Install the male green phoenix connector onto harness A.
    • Using a flat head screwdriver, loosen the terminals 3-4 turns then insert the wires into the
    • Color order does not matter but the other side of the harness HAS to match. When tightening the screw terminals, feel for when the wire end is contacted and do not overtighten. Give each wire a very gentle pull to test that they are all firmly connected.
    • Reinstall the power supply and tighten the screws.
    • Reinstall the bottom cover and tigthen the screws.
    • The vent holes should be positioned over the power supply.
  5. CR-10S BL Touch Install, Reassembly: 步骤 5 中的图像 1,1
  6. CR-10S BL Touch Install, Install 1d.: 步骤 6 中的图像 1,3 CR-10S BL Touch Install, Install 1d.: 步骤 6 中的图像 2,3 CR-10S BL Touch Install, Install 1d.: 步骤 6 中的图像 3,3
    • Your kit includes all necessary hardware for the install.
    • Using an M2 hex, remove the 2 button head screws holding the hot end shroud on.
    • Install the bracket using the provided M3x8 (or 3x10) screws.
  7. CR-10S BL Touch Install, Install 1e.: 步骤 7 中的图像 1,3 CR-10S BL Touch Install, Install 1e.: 步骤 7 中的图像 2,3 CR-10S BL Touch Install, Install 1e.: 步骤 7 中的图像 3,3
    • Plug the small end connector into the probe. It will only plug in one way so do not force it.
    • Install the probe as shown with the connection facting the hot end. Use an M2 hex to install the provided M3x6 screws.
    • You can now install the pre-crimped wires into the phoenix connector. Match the color order from the motherboard side.
    • After tigtening all screws, give each wire a gentle tug to make sure they are tight.
  8. CR-10S BL Touch Install, Install 1f.: 步骤 8 中的图像 1,3 CR-10S BL Touch Install, Install 1f.: 步骤 8 中的图像 2,3 CR-10S BL Touch Install, Install 1f.: 步骤 8 中的图像 3,3
    • Double check that the colors match from the motherboard side to the probe side and plug the motherboard side into the probe side.
    • Provided zip ties can be used to attach the new harness to the original in the locations shown.
    • Be sure to leave a little slack in the probe harness so it is not pulled on when the X axis moves back and forth.
    • Please contact us regarding firmware if you have purchased our BL Touch Kit for the CR-10S.
    • When you first power your machine on after this install and firmware has been loaded, the probe will cycle through a self test.
    • Command the machine to auto home and test the probe out with your finger to make sure it triggers the Z end stop and stops Z travel. If so, you have everything connected correctly and you're ready to go through Leveling Setup!
结论
2等其他人完成本指南。
Tiny Machines 3D
于11/16/19注册
2,970 声望
创作了14篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了40篇指南
6条评论
For the CR-10S, the 3 wire and 2 wire plug use this diagram: https://imgur.com/a/qvfqlAn. It can be hard to find the D11. Make sure the red wire is pointed towards the outside of the motherboard edge. The 2 wire plug will require you to cut the glue from the original Z connector, use a razor blade to do this. Follow the rest of the directions. The software you download and the hex file: Make sure you select the correct install as multiple come in the hex file. I only had one COM to select and the Baud was automatic. I did not plug the power cord back into the control box. I connected the box via USB and it powered on over USB. I did the firmware update like this without issue. The update took about 2 minutes and then your LCD screen will restart. Reset the items per the instructions (you will get an odd beep for each item and that's it). Once done, plug in your power cord and turn on the machine and then remove the USB. Turn machine on and Auto Home it and test the probe which should stop Z axis. Good Luck
Paul Georgelas - 回复
Lastly, this is an excellent install with great customer support. Took me an hour to do while taking my time. I recommend this to anyone with a CR-10
Paul Georgelas - 回复
Hi, I'm asking for help installing the CR-10S BL Touch
I assembled the wires on the motherboard and updated version 1.1.6BL_V3
The problem is that the sensor does not stop the Z axis
Thanks
Freddy Krueger - 回复
Try switching the pins on the two pin z stop connector. I was wiring a CR touch and that did the trick for me. (A sharp pin or very small flathead can depress the catch and allow you to slide the wire end from the plastic bracket so you can slide them out and switch)
Larry Whichone -
does anyone have the firmware for the cr-10s for bltouch ?
bst056981 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 173
总计 20,326
