跳转到主内容
Optical drive Replacement
你所需要的
  1. Optical drive Replacement, Optical drive: 步骤 1 中的图像 1,1
    • First make sure the laptop is off and closed.
  2. Optical drive Replacement: 步骤 2 中的图像 1,1
    • Unlock the battery and push the release lever to remove the battery from the laptop.
  3. Optical drive Replacement: 步骤 3 中的图像 1,2 Optical drive Replacement: 步骤 3 中的图像 2,2
    • Unscrew the four screws to remove the hard drive cover.
    • Remove these two screws to loosen the hard drive.
    • Gently slide the hard drive out.
    • The hard drive is missing from this device. (Only cover is shown)
  4. Optical drive Replacement: 步骤 4 中的图像 1,1
    • Remove all the screws that hold the plastic bottom on. There are some more screws that can't be seen in the photo.
  5. Optical drive Replacement: 步骤 5 中的图像 1,1
    • Gently pry up the plastic bottom and if it feels like it is resisting check the surrounding areas for more screws.
  6. Optical drive Replacement: 步骤 6 中的图像 1,1
    • Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. From here on out it is recommended that you wear an anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up.
  7. Optical drive Replacement: 步骤 7 中的图像 1,2 Optical drive Replacement: 步骤 7 中的图像 2,2
    • There will be a couple more screw holding in the CD tray and once you remove them the CD tray will simply slide out.
结论
2等其他人完成本指南。
Eric Martinez
于02/14/17注册
637 声望
创作了6篇指南
团队
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 768
