跳转到主内容
CM Storm QuickFire Rapid Switch Replacement
你所需要的
  1. CM Storm QuickFire Rapid Switch Replacement, Switch: 步骤 1 中的图像 1,2 CM Storm QuickFire Rapid Switch Replacement, Switch: 步骤 1 中的图像 2,2
  2. CM Storm QuickFire Rapid Switch Replacement, Remove screw on back of keyboard (labeled do not remove): 步骤 2 中的图像 1,2 CM Storm QuickFire Rapid Switch Replacement, Remove screw on back of keyboard (labeled do not remove): 步骤 2 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard.
    • This will void your warranty!
    • When inserting the screw after replacing the switch, make sure to not screw in too tight. This may cause erratic behavior with the keyboard.
  3. CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: 步骤 3 中的图像 1,3 CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: 步骤 3 中的图像 2,3 CM Storm QuickFire Rapid Switch Replacement, Seperating Back Panel from Front Panel: 步骤 3 中的图像 3,3
    • Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
  4. CM Storm QuickFire Rapid Switch Replacement, Opening Back Panel: 步骤 4 中的图像 1,2 CM Storm QuickFire Rapid Switch Replacement, Opening Back Panel: 步骤 4 中的图像 2,2
    • Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board.
    • Do not put strain on the ribbon cable when lifting the bottom panel.
  5. CM Storm QuickFire Rapid Switch Replacement, Detaching SIL Connector: 步骤 5 中的图像 1,2 CM Storm QuickFire Rapid Switch Replacement, Detaching SIL Connector: 步骤 5 中的图像 2,2
    • Detach the 4-pin cable from the bottom panel of the keyboard.
  6. CM Storm QuickFire Rapid Switch Replacement, Desolder Switch Solder Joints: 步骤 6 中的图像 1,1
    • Desolder the joints holding the switch to the board.
    • Remove the switch and solder the new switch in place.
结论
9等其他人完成本指南。
Andrew
于10/12/14注册
321 声望
创作了2篇指南
团队
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G23
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 49
总计 16,979
