跳转到主内容
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
你所需要的
  1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: 步骤 1 中的图像 1,3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: 步骤 1 中的图像 2,3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: 步骤 1 中的图像 3,3
  2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 步骤 2 中的图像 1,1
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 步骤 3 中的图像 1,3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 步骤 3 中的图像 2,3 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 步骤 3 中的图像 3,3
    • Remove the plastic rings from the keycap.
  4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 步骤 4 中的图像 1,2 CM Storm QuickFire Rapid O-ring: Large Keycap Installation: 步骤 4 中的图像 2,2
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G23
4 名成员
创作了12篇指南
一条评论
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,899
